Can domain experts build their own applications?
You know the problem better than any developer would. Here's what actually changed, and what still has to be true, for you to build the real tool yourself.
Reference
Key takeaways
  • Yes, with one real condition: you can now describe a tool in plain language and get working software, but making it a real, live application your team actually uses still needs a hosting layer that handles what a developer used to handle by hand.
  • “Domain expert” here means a non-coding professional (support, ops, finance, legal, healthcare, sales) with deep expertise in a real problem, building a tool for actual, paid use, not a hobby project.
  • The gate isn’t writing the code anymore. It’s the parts that come after: a live URL, access control, a database that holds real records, and something keeping it running when you’re not watching it.
  • A fair counterpoint exists: some argue domain experts should stay inside specialist tools rather than build whole platforms themselves. That’s a real concern for compliance-heavy systems, and a much smaller concern for the specific internal tool your team needs today.
  • Nobody has to “rebuild it properly” later. A tool built this way runs on the same infrastructure a principal engineer’s production app runs on, not a prototype that gets thrown away.
You’ve spent fifteen years running claims, or scheduling patients, or reconciling invoices, and you know exactly where the process breaks. You also know exactly what a fix would look like: a small tool, not a whole platform, that does the one specific thing your current software doesn’t. The problem was never the idea. It was that building it meant filing a ticket, waiting for a sprint that never came, or learning to code from scratch just to make one internal tool nobody else had time to build. That bottleneck is the thing that’s actually changed, and it’s worth being precise about what “changed” means, because the honest answer has a real condition attached to it.
What actually changed: the idea-to-code gap closed
You can now describe what you want in plain language, the way you’d explain it to a new hire, and an AI agent turns that into working software. That’s genuinely new, and it’s not a small thing. It means the person who understands the problem best, you, doesn’t have to translate that understanding through a developer who’s hearing about your workflow for the first time, and might miss something in the translation. You can build the thing your expertise says should exist, using that expertise directly, without it getting lost in a requirements document.
This is worth naming clearly instead of hiding behind “no-code,” a word that undersells what’s actually possible now. You’re not limited to filling out a form-builder template. With custom site development with Netlify AI, you can describe a real application, and AI generates production-ready code, the same kind of code a developer would write, just without you having to write it yourself.
What didn’t change: someone still has to answer for the infrastructure
Here’s the condition. A working prototype on your laptop and a real application your team logs into every day are different things, and the difference isn’t the code, it’s everything around the code. Someone has to give it a URL people can actually reach. Someone has to make sure that if two people use it at the same time, it doesn’t break. Someone has to decide who’s allowed to see what, especially if the tool touches anything sensitive. Someone has to keep it running at 2am on a Tuesday without you finding out from an angry coworker.
This is exactly the part of the job that developers used to own entirely, and it’s the part that doesn’t disappear just because writing the first version got easier. What’s changed is that a platform can now absorb that part too, provisioning a database, handling access control, keeping the app live on a global network, so that the domain expert who built the tool doesn’t have to become an infrastructure engineer just to keep it running. That’s a genuinely different claim than “AI writes the code,” and it’s the one that actually determines whether your tool becomes something your team depends on or something that quietly breaks the first time it matters.
A fair objection, and where it actually applies
There’s a real counterargument worth taking seriously here: that domain experts are better served working within specialist service providers, tools built and maintained by people who specialize in exactly that category, rather than trying to build and maintain an entire platform themselves. The reasoning holds up in specific cases. A specialist provider brings shared compliance work, defined service levels, and economies of scale that would be genuinely expensive for one person or one team to independently maintain. If you’re handling regulated health data across a large organization, or building something with legal liability attached at scale, that argument deserves real weight.
But notice the shape of that objection: it’s an argument against building an entire platform from scratch, not against a domain expert building the specific internal tool their team needs. Those are different projects with different stakes. A claims coordinator building a tool that tracks appeal statuses for their own team isn’t competing with a specialist SaaS provider, they’re replacing a spreadsheet and three email threads. The compliance and scale concerns that make a full platform risky to build alone mostly don’t apply at that size, especially when the underlying hosting, security, and uptime are already handled by infrastructure built for exactly this.
Who’s actually building this way, and who else uses the same platform
It helps to know you’re not the edge case here. Roughly two-thirds of the people signing up to build this way aren’t developers. They’re the same kind of domain expert: someone who knows a workflow cold and finally has a way to act on that knowledge directly. And critically, they’re not on a separate, lesser version of the platform. The same infrastructure serving a first-time builder’s internal tool is serving production applications for large engineering teams. That matters because it means your tool doesn’t hit a ceiling where it needs to be handed off and rebuilt “properly” by an actual dev team once it starts mattering. It was already built on infrastructure meant for that.
This is the practical version of building web application development with Netlify: whether the person building it is a principal engineer or someone who’s never opened a code editor, the result lands on the same production-grade foundation, not a simplified version meant to be replaced later.
Keeping it running is part of building it, not a separate job
One more piece worth being direct about: building the tool isn’t a one-time event either. Your process will change, and the tool needs to change with it. This is where the same AI-assisted approach keeps paying off after launch, not just at the start. You can manage ongoing content and data through a straightforward interface, and use AI again to make future updates, without that turning into a second learning curve. The tool you built stays something you can keep shaping, not something you built once and now have to protect from your own future changes.
That combination, real infrastructure underneath and the ability to keep iterating on top of it, is what separates “I made a thing that worked once” from “my team relies on this.” The Agent Experience framing that shapes how this infrastructure gets built matters here too: a platform designed to be legible and reliable for an AI agent to act on is the same platform that stays legible and reliable for you, the person still in charge of the tool long after the first version shipped.
FAQs
Do I need to know how to code to build a real application now?
No. You need to be able to describe what you want clearly, the way you’d explain it to a colleague. AI turns that description into working, production-ready code. What still matters is having a platform underneath that handles hosting, access control, and uptime once the code exists.
Isn’t this just a fancy form builder or no-code tool?
No. A form builder gives you a fixed template to fill in. Describing a custom application in plain language and getting real, extensible code back is a different thing: you’re not boxed into what the template anticipated, and the result isn’t a toy version that needs to be rebuilt later.
What’s the actual risk if a non-developer builds and hosts their own tool?
The risk isn’t the code, it’s the infrastructure gap: an unsecured tool, no access control, or nothing keeping it running. That risk is why the hosting layer matters as much as the AI that wrote the code. A platform with built-in identity, security, and uptime closes that gap without requiring you to become an infrastructure engineer.
Should a domain expert build an entire platform instead of using specialist tools?
Usually no, and that’s a fair distinction to make. Building a whole platform from scratch competes with specialist providers who bring shared compliance and scale. Building the one internal tool your team specifically needs, on infrastructure that already handles the hard production parts, is a much smaller and much more reasonable project.
Can I keep updating the application myself after it’s built, or do I need a developer for changes?
You can keep updating it yourself. Ongoing content and data management works through a straightforward interface, and you can use AI again for future changes, so the tool stays something you can keep shaping rather than something frozen the day it launched.
Build the tool only you know needs to exist
You already know what the tool should do. The only question left is whether the platform underneath it can carry that tool as far as your team needs it to go. Start at netlify.new and find out with the actual thing, not a mockup.
