Knowledge Base
Guides and articles to help you get the most out of the Netlify platform.
Filter by topic 0
Filter by topic:
49 articles
Reference
Can a non-developer build a web app that's secure?
October 27, 2026
Yes, because most web application security is now inherited from where the app runs rather than applied while building it. The five failures non-developers actually hit, which ones the platform removes, and the two judgments that stay human.
Reference
What does it cost to host an AI-generated app?
October 26, 2026
The hosting line is rarely the interesting number. Four things drive the cost of running an AI-generated app, only one of which is hosting, and the one that surprises people is model usage. How to model your real year-two shape instead of comparing free tiers.
Agent Guide
How to measure agent experience
October 25, 2026
Agent task success is the obvious AX metric and a poor one alone, because it improves when you remove the human's ability to see what happened. Four measures that do not have that problem, how to run a repeatable evaluation, and what the numbers usually reveal.
Migration
What happens to your code when you leave an AI app builder?
October 19, 2026
What transfers when you move off an AI app builder falls into four buckets: code, data, configuration, and the things that were never files. The first two usually come, the second two usually do not, and that gap is the real work of the migration.
Reference
What is a vibe coding platform?
October 19, 2026
Vibe coding is the practice. A vibe coding platform is the environment around it, and knowing the difference tells you what you'll actually end up with.
Tutorial
How to add error monitoring to an AI-built app
October 17, 2026
You already have more monitoring than you think, because the platform records what happened. Four layers, from reading what exists to getting notified to adding a dedicated tracker, with honest guidance on how far up the stack a small internal tool needs to go.
Comparison
Vibe coding platform vs. no-code tool: what's the difference?
October 16, 2026
No-code tools give you a bounded set of building blocks and guarantee everything inside the boundary works. Vibe coding generates ordinary code, which has no boundary and no guarantee. That one structural difference explains every other difference between them.
Agent Guide
How to deploy an AI-generated app without losing control of it
October 12, 2026
Control is not a setting. It is four things you arrange before you deploy: knowing what changed, seeing it run before it is live, being able to reverse it, and never handing over a credential. Walked in deploy order, with a worked sequence.
Agent Guide
How to build and deploy an MCP server on Netlify
September 12, 2026
A remote MCP server is one Netlify Function speaking the protocol over HTTP. The complete server, bearer auth, rate limiting, and the state trap that only breaks in production.
Tutorial
How to add a Postgres database to a Netlify app
September 4, 2026
Netlify Database is managed Postgres, built in. Install the package, write a migration, deploy. Includes the Drizzle setup and the migration rules that reject a bad deploy.
Tutorial
How to control CDN caching on Netlify
August 23, 2026
Dynamic responses aren't cached by default. Set Netlify-CDN-Cache-Control to opt in, vary the cache key deliberately, purge by tag, and read Cache-Status to debug.
Deploy Guide
How to deploy a site to Netlify
August 13, 2026
Four ways to deploy to Netlify, when each one fits, and the deploy-context config that makes it repeatable. Plus the four footguns worth knowing first.
Comparison
TanStack Start vs Next.js
August 11, 2026
A balanced comparison of TanStack Start and Next.js across architecture, type safety, rendering, data fetching, and ecosystem, plus how each deploys to Netlify.
Comparison
Netlify vs Render
August 7, 2026
A fair, technical comparison of Netlify and Render, covering platform architecture, static sites, backend services and databases, cold starts, deploys, pricing, and developer experience.
Comparison
Netlify vs AWS Amplify
August 5, 2026
A fair, technical comparison of Netlify and AWS Amplify Hosting, covering platform scope, framework support, backend services, pricing models, AWS integration, and developer experience.
Reference
Netlify’s Full-Stack Primitives: A 2026 Platform Map
August 3, 2026
A reference table mapping the primitives a modern web app needs (compute, data, storage, cache, queues, identity, AI, and more) to the first-party Netlify product that provides each, with third-party options noted.
Reference
Netlify for Coding Agents: Build and Ship a Full App
August 1, 2026
A reference for AI coding agents building on Netlify: how to publish and update a live site with the CLI, add a database and background jobs, call models through the AI Gateway, and connect the Netlify MCP server, all non-interactively.
Comparison
Netlify Drop vs Vercel Drop
July 30, 2026
A fair comparison of Netlify Drop and Vercel Drop, two drag-and-drop deploy tools, covering account requirements, build handling, file support, and updates.
Comparison
Netlify Blobs vs Vercel Blob
July 28, 2026
A fair, technical comparison of Netlify Blobs and Vercel Blob, covering data model, consistency, metadata, size limits, browser uploads, and pricing, with code for both.
Migration
Migrate to Netlify from Vercel
July 26, 2026
A step-by-step guide to moving a site from Vercel to Netlify, covering build settings, environment variables, redirects, headers, functions, and DNS cutover with zero downtime.
Deploy Guide
Deploy Your v0 App to Netlify
July 24, 2026
Publish an app you built with v0 (Vercel’s AI app builder) to Netlify, either by syncing to GitHub for continuous deploys or by exporting the code and deploying with the Netlify CLI.
Deploy Guide
Deploy Your Lovable App to Netlify
July 22, 2026
Publish an app built in Lovable to Netlify through GitHub for continuous deploys, or drag the built files to Netlify Drop, including how to carry over Supabase keys.
Deploy Guide
Deploy Your Google Stitch App to Netlify
July 20, 2026
Export a UI from Google Stitch and publish it to Netlify by dragging the static HTML into Netlify Drop, with a path to graduate to a Git-connected project.
Deploy Guide
Deploy Your Bolt App to Netlify
July 16, 2026
Publish an app you built in Bolt.new to Netlify, either with Bolt’s one-click Netlify integration or by connecting your repository for continuous deploys.
