Netlify Drop vs Vercel Drop
A fair comparison of Netlify Drop and Vercel Drop, two drag-and-drop deploy tools, covering account requirements, build handling, file support, and updates.
Comparison
At first glance, both tools do the same thing: drag a folder into the browser and receive a live URL—no Git repository, CLI, or local setup required. The biggest differences are whether you need an account before deploying, how each platform handles future updates, and how the deployed project is managed over time.
Netlify pioneered the drag-and-drop deployment model, originally introducing Netlify Drop through co-founder Mathias Biilmann’s earlier BitBalloon service. Vercel introduced Vercel Drop in June 2026. This guide focuses on the design differences between the two experiences.
What each one does
Netlify Drop (app.netlify.com/drop) accepts a folder or ZIP file and publishes it to a netlify.app URL. You can upload prebuilt static files or an entire project folder. If Netlify detects a package.json or another supported project manifest, it installs any dependencies and runs the build automatically. You can deploy first without creating an account, then claim the site later.
Vercel Drop (vercel.com/drop) accepts files, folders, or ZIP archives, including unbuilt framework projects. It detects the framework, installs dependencies, builds the project, and publishes it to a production URL under a new Vercel project. You must sign in with an account before deploying; the free Hobby plan is sufficient.
The build step
Both products support the same two workflows: deploying prebuilt static assets or uploading an unbuilt framework project for server-side building.
Netlify Drop publishes prebuilt static files exactly as they are. Drag a folder containing HTML, CSS, and JavaScript or a dist/ folder you’ve already built—and you’re done. If the uploaded content is a full project, Netlify can automatically detect the framework, install dependencies, and run the build before publishing the output.
Vercel Drop behaves similarly. Drop an unbuilt Next.js or Vite project, and Vercel detects the framework, installs dependencies, builds it server-side, and publishes the result.
Account and friction
Netlify Drop lets you deploy a site without creating an account first. You receive a live URL immediately and can claim the site later by signing up. That makes for the lowest-friction first deployment.
Vercel Drop requires you to sign in before deploying, and it creates a project associated with your account from the first deployment.
If your goal is to publish something as quickly as possible with zero commitment up front, Netlify Drop gets you there faster.
Updating your site
Another important difference is how subsequent deployments work.
Netlify Drop keeps your project in your dashboard, where you can view deployment history and drag updated files onto the existing project. The changes publish to production while keeping the same URL.
Vercel Drop creates a new project as part of the Drop workflow. To continue updating a single site over time, Vercel encourages connecting a Git repository so deployments happen automatically.
Size limits
Netlify documents that Drop deployments work best when the total upload is under 50 MB, and notes that individual files larger than 10 MB may cause deployments to stall. For larger projects, it recommends using the Netlify CLI.
AI coding agents such as Claude or Codex can automate CLI-based deployments, so using the CLI does not require setting up a GitHub repository. Guidance for AI agents is available at https://netlify.ai.
Vercel does not currently publish specific size guidance for Vercel Drop, so it’s worth testing with a representative project if you’re deploying larger sites.
Side by side
Dimension Netlify Drop Vercel Drop
Account to start Not required; claim later Required (free Hobby plan)
What you drop Folder or ZIP, including unbuilt framework projects Files, folders, or ZIP archives, including unbuilt framework projects
Build step Automatic when a framework is detected Automatic when a framework is detected
Result netlify.app URL that can be claimed later Production URL under a new Vercel project
Updates Drag updated files onto the same project or connect Git Connect Git for ongoing updates
Documented size guidance Under 50 MB recommended; files over 10 MB may stall Not published
Missing index.html at root May not display correctly Prompts you to select a root page
First released 2015 June 2026
Which should you choose?
If you’re deploying prebuilt static files, both tools work well. Netlify Drop gets you online without requiring an account, and Netlify’s documentation explicitly highlights AI-generated static output as a primary use case. The Deploy from an AI code generation tool guide covers Netlify Drop alongside the CLI and other deployment paths.
If you’re uploading an unbuilt framework project, both platforms install dependencies and build the project automatically. At that point, the primary differences are the upfront account requirement and how future drag-and-drop deployments are handled.
Tip: keep an eye on project size. A complete project folder is often much larger than its build output, so deleting node_modules before uploading is recommended. The platform will reinstall dependencies during the build.
For quick experiments, both tools are effective. As a project grows, connecting a Git repository becomes the better long-term workflow, enabling automatic deployments, preview environments, and collaboration.
Resources
